Winch identifications jd 350
T19800T
Re: Winch identifications jd 350
There is two sets of numbers T 19801t is above inspection cover
T19800T is on the brake band side
Drop the T suffix off the number and those are numbers for components of a 3315 winch, in looking at JDparts, for winches used on 350's. Is that what you were looking for?
Three numbers now T 18586T on the inside of inspection cover plate
Yes I was trying to find out what winch I have .... a case of brake cleaner later and 23701 is stamped on the top of the winc
You are saying it is a 3315
That is where those number show up. Go to JDparts: Homepage and you can research further. Enter your model number; I picked a 350 crawler tractor based on your post title and looked at the winches; they show two the 3310 and the 3315. I did a search for T19800 for the 3310 and it didn't come up, tried the same on the 3315 and it came up. There likely was a metal tag, on the top and just ahead of the winch drum opening, that had the model and serial numbers on it originally. The 23701 shows as the housing marking when I just searched 23701.
Yes I would say it is highly probable your have a model 3315 winch.
Users browsing this forum: Google Adsense [Bot], NevadaKid and 205 guests
