Main Pump
77 Ford
Main Pump
Post by 77 Ford » Mon Mar 12, 2018 8:10 am
My main hydraulic pump is starting to leak. It leaks about a drip every 12 to 15 seconds(not under load at idle). I assume the pumps can be rebuilt but looking at the parts breakdown it doesn't appear there is a bushing in the front plate for the input shaft which is where it's leaking. Do I have to purchase a new front plate or do you have to replace the whole pump? I know most of the time just putting seals in will not stop the leak for long as there typically something wore out that makes the seal go bad.
JD- 450C track loader
Serial #208336T
jsal
Re: Main Pump
Post by jsal » Mon Mar 12, 2018 12:45 pm
I was able to find a kit for my 350 on e bay some years back was not making good pressure found blown out seal working good now
JIM
pondhogvt
Re: Main Pump
Post by pondhogvt » Mon Mar 12, 2018 9:31 pm
77Ford, JD Parts book shows that as a shaft seal for main hydraulic pump.. depends which pump you have and which machine but it is replaceable.. I would say it is worth a try for the cost of a seal.. if that doesn't work you can always buy a pump after..
from my 350C book.
ah15442 for 15gpm pump
at59652 for 27gpm pump. loader
good luck Mark.
77 Ford
Re: Main Pump
Post by 77 Ford » Mon Apr 16, 2018 7:00 am
Just a quick follow up for closure. I removed the main pump and there was zero play in my input shaft. I think the seal had simply dry rotted out. I was able to source a seal. I called every bearing/seal place within an hour of me no one had it and it was going to be between 18 and 30 dollars. I found one at John Deere, in stock for 15 bucks.....
It's all back together and while I've not worked the machine I let it run for over 15 minutes and no sign of a leak yet.
I'd say the hardest part of the project is lifting the 5 gallon bucks of oil up to refill the reservoir, wan't much of a project at all.
Serial #208336T
Users browsing this forum: Majestic-12 [Bot] and 32 guests
