Need some info 1010 crawler loader. The cooler for the reverser is missing, is this a high pressure cooler, or will a automotive trans cooler work. what is the working presssure for the reverser.
Keith
1010 loader reverser
Keith
Re: 1010 loader reverser
Early crawlers were an air to oil cooler on the front of the radiator, later were oil to water in the radiator.
About 135 PSI is system pressure, so automotive cooler will work. There are some better quality hyd coolers out there with threaded fitting that may be easier to adapt to.
Was curios on the trans cooler, there is a trans cooler attached to the radiator, but reverser lines are not hooked to it. I will look for another cooler with fittings.
Thanks Lavoy for the info
Keith
Someone must have disconnected it in the past.
Users browsing this forum: No registered users and 230 guests
