JD430C
Post
by JD430C » Tue Mar 27, 2007 9:19 pm
hello guys, heres a few pics of the 1010 i bought from diggerlarry. i need to fix the clutches, wiring, and i am thinking of installing a reverser in it. going to take it to the local plow days this spring if i can get it fixed in time.
andrew
Post
by wwattson » Wed Mar 28, 2007 6:32 am
Great looking crawler Andrew! It's got the same blade that mine has. I got a book for a 63 blade and everything matches what you and I have with the exception of the mounting frames. Do you know if it is still a 63 blade or do they get a different model number when they were made the new frames?
JD430C
Post
by JD430C » Wed Mar 28, 2007 7:25 am
thanks bill. my 1010 brochure lists the inside manual angle blade as a 610. only difference between mine and yours is mine has the optional 7ft blade. i might try to find a 612 for it, as my 350 had a 6way and i like them a lot more than the manual angle blades
andrew
Post
by wwattson » Wed Mar 28, 2007 9:02 am
Thanks Andrew. I know what you're saying about the manual blades. Doing the horse arena last fall hopping off the crawler 2 or 3 times a day to fight with adjusting the blade manually was no fun.
hunter41mag
Post
by hunter41mag » Sat Mar 31, 2007 12:54 pm
Andrew,
Looks good and that everything is there. I am sure with a little TLC that you will have it like new in no time. Good luck with it.
Don
Eastern PA
440IC (1960)
JD430C
Post
by JD430C » Sat Mar 31, 2007 7:36 pm
thanks don. one side panel under the dash is missing, but they usually are. planning on putting it in the shop this week to fix the finals and wiring. planning on taking it to 3 plow days this april, just got a top link for it and i have a 3 bottom plow that it should pull easily.
andrew
DiggerLarry
Post
by DiggerLarry » Mon Apr 02, 2007 9:02 pm
Glad to see it got home OK. Looks good in the northern air. Be sure you post some pics when you get it done.
DiggerLarry
