John Deere 420 C
Re: John Deere 420 C
Post by Lavoy » Wed Sep 06, 2017 5:02 pm
If you disconnect both brake rods, and take the brake pedal off, you can slowly work the cross shaft to the left. As you do, you can emery cloth the shaft and clean it up. It is a pain in the rear, but better than splitting the crawler.
Post by Stan Disbrow » Thu Sep 07, 2017 8:00 am
When I said 'take it apart', I meant what Lavoy just said: the pedal parts. I hope no one thought I meant split the machine. That *would* be a major PIA. Makes messing with the pedal parts just a *minor* PIA! ;)
bookman51
Post by bookman51 » Fri Sep 08, 2017 5:13 pm
I got it loose enough to get the crawler going again. I took it out and ran it for 30 minutes or so working the handles. I am pretty sure now that it is a matter of the clutch and brake sticking together and the brake does not letting the clutch engage. It is interesting, I can engage the clutch, put it in gear, and then nothing....until I start working the handles. Then the clutch seems to engage.
I did change the points this past fall, and I am pleased that the crawler is starting right off, but it found another way to frustrate me.
I will keep putting penetrating oil on the shaft. I cannot say the shaft is getting any looser. I just put a block of wood in behind the clutch and force the brake pedal down. Then upon releasing the brake the clutch pedal goes back far enough to engage. If get ambitious, I will do what Lavoy suggested regarding the emory cloth. At this point I probably have worked the clutch and brake pedal back an forth a couple hundred times and they do not seem any looser. I still have to do it with my foot I cannot hold one with my hand and force the other forward.
Work on the crawler is not exactly the handiest thing to do. Thanks for all the good advice and help.
Post by Lavoy » Fri Sep 08, 2017 5:49 pm
If it has not loosened up by now, it isn't going to without cleaning up the shaft.
bookman51
Post by bookman51 » Sat Sep 09, 2017 8:16 am
Lavoy, I was afraid you might write that!!! :lol:
Steven Walters
Post by Steven Walters » Sun Sep 10, 2017 6:58 am
My brake and clutch pedal are rusted together as well, I need to split crawler for sure. What is most efficient way to split? In parts book it looks like there is a spring on shaft on the inside, You would think it's broken worn out by now. Do I have to remove shaft completely from machine to clean up and change spring? Looks like I can remove trans and final drive reiltivly quick. Just wast wondering what I was in for.
Post by Lavoy » Mon Sep 11, 2017 9:30 am
Shaft will not come out with center section still in the crawler. Never had a spring wear or break in that location. I would try and fix it without splitting it first.
Steven Walters
Post by Steven Walters » Mon Sep 11, 2017 12:41 pm
I have bin trying trust me. Where does shaft from trans to engine come apart? I was going to pull trans and finals off, then take the front half and pick up off cross members.
Post by Paul Buhler » Wed Sep 13, 2017 5:30 pm
My clutch/brake sleeve weren't a problem for me, but based on others expressed problems, a few years ago I hooked up my power washer and gave my brake/clutch shaft a good cleaning. As Lavoy has said in the past, water is a universal lubricant and gets into rusted parts best. I followed up with lithium grease from a can. Anyway, My clutch and brake work independently as designed and I regularly squirt oil into the available ends hoping to avoid a problem. Good luck with your machine, and best regards. Paul
Post by Stan Disbrow » Thu Sep 14, 2017 6:04 am
We (meaning first my dad and then myself) have been spraying that half n half penetrating oil and lithium grease into each end since 1966. Still no problems. :)
Then, too, the machine has been under a shed roof almost all of those days. That really helps. But there are still those days, mostly in the winter, when the air warms up and all that cold iron becomes wet as a sponge. I think that yearly spraying of what otherwise is a pretty lousy product does work.
Post by Paul Buhler » Thu Sep 14, 2017 5:09 pm
I also like to spray some diesel oil into the ends from time to time figuring that it may help some of the rust sludge break down and wash away. Cheap, and a spray bottle fits into the available spaces.
Users browsing this forum: No registered users and 249 guests
