Hyd track adjustment
Bruser
Post by Bruser » Thu Aug 24, 2017 3:44 pm
Sorry for the rookie question, but this is my first crawler! I have a 440 with a 831 loader. The tracks on the left side have become slack ( more than the right side). It has Hyd track adjust. My question: is there a special grease gun needed to "pump up" the adjuster.
I don't have the service manual but the operator manual says to use 140 gear oil. I don't thing my current grease gun will do that without making a real mess :roll:
Some help from the experts would be appreciated :)
Re: Hyd track adjustment
Post by mini kahuna » Thu Aug 24, 2017 5:08 pm
you need a low pressure grease gun, I use corn head grease for both my bottom rollers and the track adjuster.
you most likely still have the button head grease fittings for your adjuster and rollers, they look like little mushrooms....you can get the special fitting to screw onto a low pressure gun and you will be all set.
Lavoy might sell them or deere will have them.
you can use a regular grease gun for your adjuster but using regular pressure gun on bottom roller you can blow out the seal without even knowing it....using the low pressure gun gives you a better feel for amount if lube you have pumped into rollers
1010 loader
Bruser
Post by Bruser » Thu Aug 24, 2017 7:39 pm
Thanks for the reply, I'll give the adjuster a shot with the current gun I have and search out the fittings for the L/P one.
Post by Stan Disbrow » Fri Aug 25, 2017 4:07 pm
Here is a good place to start:
viewtopic.php?f=2&t=10405
gregjo1948
Post by gregjo1948 » Sat Aug 26, 2017 5:15 am
I think you can get the grease gun fitting at NAPA.
Post by Lavoy » Sat Aug 26, 2017 12:18 pm
I stock ends and zerks.
Bruser
Post by Bruser » Mon Sep 04, 2017 9:04 pm
Lavoy:
How do I go about getting an end for the "Mushroom" head fitting?
Post by Lavoy » Tue Sep 05, 2017 9:47 am
Give me a call 701-361-1006.
Users browsing this forum: No registered users and 157 guests
