After working a while the main clutch or reverser is slipping. What's the best way to determine what's slipping?
Thanks, gregjo1948
440IC slipping
440IC slipping
Re: 440IC slipping
The main clutch will be "thin" if it is slipping. In other words, the slightest pressure past free travel will increase the slip. You need to pull the engine, regardless.
Re: 440IC slipping
Make sure it isn't your steering clutchesoriginal possum wrote: ↑Wed Aug 02, 2017 9:11 amThe main clutch will be "thin" if it is slipping. In other words, the slightest pressure past free travel will increase the slip. You need to pull the engine, regardless.
Users browsing this forum: No registered users and 157 guests
