350 B Lower Radiator Hose
This may seem quite simple but is there a trick to replacing the lower Radiator Hose on at 350 b? With the grill out I can "feel" the hose clamp on the Radiator, but no way can I get on it to loosen. Does the Radiator need to come out just to put the hose on? Thanks for any advise in advance.
Re: 350 B Lower Radiator Hose
It may be possible to get to by removing, I believe, 2 of the three bolts at bottom of of the hard nose, and tilting it forward. This may give you access to the bottom rad hose.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Thanks. Been on vacation back at it
Now. I'll give that a try!
Users browsing this forum: No registered users and 34 guests
