JD1010 Crawler Cranking Problem
TunkCreek
Post by TunkCreek » Sat Jun 17, 2017 4:47 pm
John Deere 1010 Crawler Diesel. Starter will crank motor about a 1/4 turn then hits a dead stop. Hitting the starter again I get just a thunk (technical term :) . I can manually turn the crank with a pry bar and try to start again. It will crank but with the same result. Good battery, good starter and good connections. I have no idea what is preventing the crank from rotating to get it started.
original possum
Re: JD1010 Crawler Cranking Problem
Post by original possum » Sat Jun 17, 2017 6:06 pm
Probably a blown headgasket between two cylinders. Barring over moves most of the water to the other cylinder. Crank a while and you may bend a connecting rod.
whiteclipse16
Post by whiteclipse16 » Mon Jun 19, 2017 11:03 am
Sounds like you have something hitting in a cylinder. As stated before, you will bend a push rod if you haven't already.
Ben
gregjo1948
Post by gregjo1948 » Tue Jun 20, 2017 3:43 am
Pull the valve cover and ckeck to see if the valves are OK. Maybe you dropped a valve into a cylinder.
