david brown charging issues
dtoots1
Post by dtoots1 » Wed Jun 14, 2017 8:47 am
It has a voltage regulator separate from the alternator....is not charging and need to know how to test voltage regulator and alternator.
thanks
dtoots1
Re: david brown charging issues
Post by Stan Disbrow » Thu Jun 15, 2017 4:41 am
The ignition switch feeds power to the cut-out of the regulator. Make sure there is power there first. Then, the regulator feeds power to the field coil of the alternator. Check that line with a voltmeter and see. If you don't have power there, the regulator is bad. If you do, then the alternator is bad.
dtoots1
Post by dtoots1 » Fri Jun 16, 2017 8:14 am
Thank You Stan you the man with all the electrical knowledge!!
thanks again
dtoots1
