Jd 1010 stearing clutch
Daveg
Post by Daveg » Thu May 25, 2017 1:43 pm
Thank you for letting me join! I recently bought a jd 1010 crawler from an old man who has owned it all of his life.
The steering clutch was worked on by him but was never put back together properly, I bought the new parts and put them in, but the pressure plate when bolted on maxed out the three fingers. Is there supposed to be shims under the 6 pressure plate bolts, or do I need a gauge to adjust the fingers on the new pressure plate?
Thank you
Dave G
original possum
Re: Jd 1010 stearing clutch
Post by original possum » Thu May 25, 2017 3:39 pm
IF you are CERTAIN your assembly is correct (with six friction and five steel plates in proper position) then you can adjust the fingers. You will need a gauge available from Lavoy (usually). But it really says the assembly is not correct. You did not say which way the pressure plate is maxed.
Daveg
Post by Daveg » Thu May 25, 2017 4:16 pm
Inside of brake drum it it written to use 8 fiber, and 7 steel discs, which is the same amount I bought in a lot. The fingers are all the way in, it does seem like there is to many disks, but that is what drum calls for
Daveg
Post by Daveg » Thu May 25, 2017 4:27 pm
Post by Stan Disbrow » Fri May 26, 2017 6:14 am
Hmmm. I thought the 1010 was 7 fibers like the 420. The 350 uses 8, and the pack of discs comes with 8.
Daveg
Post by Daveg » Fri May 26, 2017 7:29 am
How can I post an picture?
Like I said drum says 7 steel 8 fibre, the last clutch fibre sticks out about three sixteenth of an inch beyond drum, so when you tighten down 6 bolts to attach pressure plate
The three fingers are maxed out so there is no way for the throw out bearing to push them in any more. Maybe I just need to adjust them with that tool?
Post by Lavoy » Fri May 26, 2017 8:13 am
All steering clutch pressure plates on all Deere dry cutch crawlers have to be adjusted once the clutch is assembled.
1010 is normally 8 fiber and 8 steel, but there are factory labelled brake drums like the one in question here.
Daveg
Post by Daveg » Fri May 26, 2017 8:15 am
Ok, great! So I need to buy the gauge from you?
Post by Lavoy » Fri May 26, 2017 8:25 am
I should have one in stock. I am getting low, but have another batch coming shortly.
Users browsing this forum: No registered users and 236 guests
