jd 2010 ignition ?
jd 2010 ignition ?
I am still working on my dad's old 2010, and i have realized i do not think he had the key for and wired the ignition to the on position possibly. i know he used to put a battery in it only when he wanted to use it then remove the battery when done. i know to start the 2010 i need to push the button , but how do i turn it off ??
Re: jd 2010 ignition ?
This is a gas crawler I assume. Disconnect the battery cable. Or quickly remove the big wire from the coil, but you will still have current thru the points and coil primary.
Thank you ! It is a diesel. Can I still disconnect the battery to get it to shut off ?
I think you can. I believe it has to have electrical power to operate a fuel solenoid that allows fuel to the injector pump.
IIRC, the original IPs used mechanical fuel shut-off, done by moving the lever all the way down.
Thank You All for the help!
I am probably a couple of months away from trying to crank this thing, but causing a little anxiety
Users browsing this forum: No registered users and 201 guests
