1010 fix or part it
Antler boy
1010 fix or part it
Post by Antler boy » Sun Apr 09, 2017 5:14 am
I have a 1010 project. I purchased it scrap value but I hope to make it usable again. The previous owner pulled the old gas engine when it went bad. He dropped a cummins diesel, fit and hook up look pretty good. Overall the track looks to be usable shape still and has a 6 way blade. My question is this, it looks like the cummins rotates cw when facing the front. Is this the correct rotation? Thanks in advance.
Post by Lavoy » Sun Apr 09, 2017 9:16 am
I hope that is a really small Cummins or the drivetrain will not survive for long.
Rotation sounds correct.
Antler boy
Post by Antler boy » Wed Apr 12, 2017 8:12 pm
Thanks for your reply. Unfortunately it is too large so a replacement engine if available may be the best option if down the road. For now i plan to start going through and checking it all out so I can make a decision on it.
pop pop
Post by pop pop » Fri Apr 14, 2017 1:53 pm
i think there are a bunch of other older small plain engines that would be a better choice, some may even bolt right onto bell.
Post by Tigerhaze » Fri Apr 14, 2017 3:09 pm
Antler Boy-
There are a number of posts from several years back where we discussed sources of used replacement engines for 1010 crawlers- the obvious ones were other 1010 crawlers, and 2010 crawlers if you wanted a reasonable power upgrade. However other sources included wheel tractors, combines, etc. that used engines similar to those used in the 1010s and 2010s.
http://www.jdcrawlers.com/messageboard/ ... ight=ha165
http://www.jdcrawlers.com/messageboard/ ... ht=combine
Users browsing this forum: No registered users and 233 guests
