Steering clutch pressure plate setting with gauge
Post by Lavoy » Mon Feb 26, 2007 9:44 pm
I just posted a pic in the FAQ section that is from a factory service bulletin on how to set steering and engine clutch pressure plates. You should be able to print the image and then you will have it for reference.
Howard Yoder
Post by Howard Yoder » Tue Feb 27, 2007 4:37 pm
Thanks Lavoy I made a copy and put it in my service manuel.
Little John
Post by Little John » Thu Mar 01, 2007 8:43 pm
Lavoy, Thanks for the #286 Service Bulletin on use of gauge JD-7. I'll mark mine as indicated, because at my present rate of work I'll probably have lost what memory I have left when I get to reinstalling the steering clutches.
Post by Lavoy » Fri Mar 02, 2007 10:07 am
You might be able to take the image and save it to your computer. I guess I did not try it, but that is what I hoped would work. If not, e-mail me and I can send it to you.
Little John
Post by Little John » Fri Mar 02, 2007 10:15 am
Yes Lavoy, I was able to save it to the computer and make a hardcopy. It is a .jpg file.
Users browsing this forum: No registered users and 189 guests
