Hi guys little background my 1010 has been siting about 3 years
with A problem with the starter gear on the flywheel. Pulled it in the
shop last weekend started to pull the motor I pulled the oil dip and the
oil pan full of antifreez checked the radiator empty .
what do you think? time to scrap or? appreciate any help
Thanks crawler Mark
1010c watter in oil
I don't have near as much experience as Lavoy but short of tearing down the engine, it seems that you could drop the bottom plate off the crawler to get access to the oil pan, drop the oil pan, and then use a cooling system pressure tester to put the system under pressure. At that point you could look up into the bottom of the block and see if there is water leaking past the cylinder sleeve deck sealing rings.
Users browsing this forum: No registered users and 220 guests
