gearmatic winch master control
jd630luvr
Post by jd630luvr » Mon Mar 06, 2017 7:23 pm
My first post. hope this works ok! Working on brake side of master control.Does part no. 127 (brake piston) have a hole through the center? mine does not have the hole as shown in parts book. Are piston and brake push rod still available? Thanks Bob
420c 62 blade 8a winch
notmeu
Re: gearmatic winch master control
Post by notmeu » Mon Mar 06, 2017 9:29 pm
Some of the older Gearmatic parts are interchangeable with the newer parts. Take a look at the model 19 parts, I think it is the newer model number, and compare the parts. There was a few parts that I had bought new that fit my gearmatic 8a and also for the original winch controller.
Post by Ray III » Sat Apr 09, 2022 7:20 am
When you apply the clutch, is the winch supposed to reel in with the brake applied? I was under the impression that the master control had some gimmick for relieving pressure on the brake at the same time that the clutch was engaged, but after taking it apart they seem to be completely independent.
Post by Lavoy » Sun Apr 10, 2022 9:27 am
No, brake is self-applying, it only disengages when spooling out.
Post by Ray III » Mon Apr 11, 2022 2:17 pm
I think what you are saying is the brake grabs in one direction but not the other? It seemed to winch really hard when using it without the controller and a stuck clutch, but that may have been from the excessive amount of rust. (I was using the reverser to spool out cable which is how the clutch arm broke.)
Everything seems to be working except I need a new nipple, clutch fluid ran right out of it with a new U-cup. And the master control shaft leaks, I assume there is something for it in the rebuild kit.
Post by Lavoy » Tue Apr 12, 2022 8:46 am
Kind of. It always will have drag when spooling in, but the brake will "slip" while it is spooling in. When you pull out, the brake self applies and holds the load until you disengage it with the MCU. Even then, they have some drag while the brake is disengaged, but not much if adjusted properly.
Working on your order, waiting for some parts to come in.
Users browsing this forum: Hurlbutt and 251 guests
