New to me 350C needs track adjusters
Nut4Trucks
Post by Nut4Trucks » Mon Feb 06, 2017 11:43 am
First I would like to thank the institutional knowledge of this forum. I have been reading a lot and I just picked up a 1985 JD350C forestry dozer last week. I knew it needed at least one track adjuster, but I have just decided to bite the bullet and buy both of them. It has 1030 hours on it and according to my buddy, who works where they run 3 JD350s everything else is in great shape. So, finally to my question where is the best place to buy the adjusters? Is everything now aftermarket and one is as good as the other? I plan on keeping this dozer for the rest of my days as I bought it to clean up a 60 acre neglected farm that I plan on retiring to within the next few years. Thanks in advance for your advice/input.
jsal
Post by jsal » Tue Feb 07, 2017 5:03 am
you might look into replacing the seals lots cheaper than replacing the adjusters you need two seals per side T37660 and AT 13014 about $110.00 from John deere check them out
JIM
Nut4Trucks
Post by Nut4Trucks » Tue Feb 07, 2017 7:50 am
I appreciate the input. Judging by the rest of the adjuster it is more than likely too pitted for the seal fix. I pulled it out in an attempt to get to a clean unpitted area of the cylinder and pumped it up got the track adjusted and it did not hold but 20 minutes of running the dozer. I do not want to waste money but I also do not want to have to do this job several times.
1985 JD350C Forestry Dozer
Post by Lavoy » Tue Feb 07, 2017 10:13 am
I have new adjusters available.
Nut4Trucks
Post by Nut4Trucks » Tue Feb 07, 2017 10:28 am
Mr. Lavoy would you please send me the price shipped to 37042 via a message?
Thanks,
Tony
Post by Lavoy » Tue Feb 07, 2017 2:09 pm
Messages are dead for right now, e-mail me at postmaster@jdcrawlers.com
Thanks,
Nut4Trucks
Post by Nut4Trucks » Tue Feb 07, 2017 2:18 pm
Just sent you an email.
cdunn
Post by cdunn » Tue Feb 07, 2017 6:20 pm
After searching numerous sources Lavoy had best price on 350 adjusters.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Nut4Trucks
Post by Nut4Trucks » Wed Feb 08, 2017 2:32 pm
Thanks, I got his quote and it looks like you are correct.
Users browsing this forum: No registered users and 216 guests
