Hello. If anyone can help, I need the measurement of the depth of the step on the face of a JT30042 rear crankshaft seal install tool. I need to build a JT30042 seal install tool for my 1120 tractor. According to what I could find on part numbers, my 450C and 1120 tractor can use the same rear crankshaft seal. RE44574 or AR92893. This is a seal with the built in wear sleeve. It is not two separate pieces. The seal and wear sleeve must be pushed in together or it will be damaged. I do not know what the step should be from the face of the wear sleeve to the face of the seal.This is not explained very good but if anyone has a JT30042 seal install tool and could give me the depth of the step on the face, I would greatly appreciate it.
Thank you,
David Edwards
450C Rear Crankshaft Seal Install Tool JT30042
Pulled my rear cover off and removed the seal to my surprise the seal was nothing like I had encountered before it is a flat face that runs against the
inside surface of the cover the other suprise is the price $ 249.00 from deere
found one online they wanted 125.00 but did not have the seal found one one E bay $229.00 ouch .there is nothing cheap about fixing machines two other places I checked with wanted $285 00
JIM
JIM
Users browsing this forum: jimmydiesel and 215 guests
