440- Rock guards- Install or not?
- 440 iron popper
Hello, I am currently rebuilding the side frames of my 440. Extraction of bolts, then sandblast. More than 2 lines= debug mode... sorry
GO here http://www.jdcrawlers.com/messageboard/ ... highlight=
and/Or here http://www.jdcrawlers.com/messageboard/ ... highlight= Then edit away
- 440 iron popper
I will install new rollers and hardware, paint them etc. I ve been told to not put the rock guards on because they just pack the mud, dirt between them and break bolts. Especially if they don t help to guide the chain, i m thinking about not installing them. What is your idea on that? I use the dozer in the woods so it drives on soil, mud, vegetation but no rocks. Thanks!
- 440 iron popper
Today is seems to want short paragraphs, no more than two lines, even when editing. Sigh.
- 440 iron popper
Thanks pop pop. If it helps guiding the rails i will install them otherwise it would be off to help self cleaning. Do you think roller flanges alone are not enough?
I have one on, and the other off, on my 350b. Three times I have had the track off on the side without the guards. Every time in a hole or in deep bush, Each time I promise myself to put that one back on. It is still off. This spring I promise.
backhoe attachment.
backhoe attachment.
- 440 iron popper
Scottyb, thanks for your input. That s exactly why the dozer is in the garage this winter for. I don t want to throw a track off in the woods anymore... i will install them. Better work in the garage than in the mud trying to be back on tracks.
Rockguards are structural on any 5 roller crawler, always reinstall.
- 440 iron popper
Thanks Lavoy. I will. About the 10 spacer pipes... The id of the spacer pipe is .824 on jdparts.com. The original bolt that goes through it is 5/8. I Think i will install 3/4 threaded rod in there. Rock guard to track frame bolts are all 9/16 now from previous repair i guess. Some more work ahead.
Users browsing this forum: No registered users and 174 guests
