combined weight of jd440 and 6 way hydraulic
dtoots1
Post by dtoots1 » Thu Jan 19, 2017 7:15 am
Lavoy and others,
I can find what the jd440 weight is...but i cannot find out what the combined weight is with a 6 way blade....decals numbered is 64?
thanks!!
Post by Lavoy » Sat Jan 21, 2017 5:25 pm
7000 if I had to guess
Gil
Post by Gil » Sun Jan 22, 2017 11:50 pm
JD440IC bare weight 5,850 lb.
JD440IC working weight 6,380 lb. (rock guards, deluxe seat, direction reverser, lights, bottom plate, hydraulic control and cylinder, fuel, & oil)
JD440ICD bare weight 6,000 lb.
JD440ICD working weight 6,550 lb.
JD64 blade should be less than 1,000 lb. I guess.
Looks like you found a crawler to buy!
Gil
Post by Lavoy » Tue Jan 24, 2017 5:26 pm
62 blade is 1,250 or so, would guess 64 at 1500, 3 more cylinders, and lots more iron.
dtoots1
re..wt
Post by dtoots1 » Wed Jan 25, 2017 12:19 pm
well guys that helps but sure puts me in a quandary!
Lessen i can get a light enough trailer...that puts weight at almost 8000lbs
(7880 at 1500 for blade, hydr etc...)
thanks, you guys are really great
dtoots1
dtoots1
re..wt
Post by dtoots1 » Wed Jan 25, 2017 12:21 pm
had more to say but got debugged...
shortened msg and it took
Users browsing this forum: No registered users and 186 guests
