Hello Everyone
I have a 1010 crawler loader that has had the engine replaced so no tag. However based on part number breaks I think that it is between 24694 and 31000. I need a gear in the final drive. The part number in the book is AT13081T, but the numbers on the gear itself is T14588T and T17481T. Do you have one Lavoy?
Also, if you stand in front of the machine and look at the front of the tracks they " lean in"
I mean there is a shorter distance between the top of the tracks than the bottom. Is this normal?
Thank you
1010 final drive
1010 final drive
1956 JD Model 50 Row Crop
1958 Ford 841 Powermaster
1962 1010 Crawler Loader
Should have, just got back, been out of state all week. Give me a call at 701-361-1006, should be in the shop later tomorrow.
1010 final drive
Hi Lavoy
I received the new Bull Gear with no problem. It was packed very well. It fit the old shaft quite snugly, but we used the Locktite as you suggested. We are back in the woods ready to go!
Thanks for all of the help
Clayton
Clayton
