swap 2010-1010
gregjo1948
swap 2010-1010
Post by gregjo1948 » Sun Dec 04, 2016 7:10 am
Will a 2010 engine interchange with a 1010? Thanks, gregjo1948
whiteclipse16
Post by whiteclipse16 » Sun Dec 04, 2016 7:22 am
I think you can theoretically put a 2010 gas in place of a 1010 diesel. You have to play some games with the flywheel to make the 1010 flex plate work.
whiteclipse16
Post by whiteclipse16 » Sun Dec 04, 2016 7:25 am
Lavoy knows more but will advise against it due to power increase.
JD430C
Post by JD430C » Sun Dec 04, 2016 1:03 pm
Yes they will interchange. I have done it. Flywheel from a 1010 will bolt to a 2010. You will have to swap the water pumps around as the plate that they bolt to is different.
Andrew
gregjo1948
Post by gregjo1948 » Mon Dec 05, 2016 4:03 am
Thank you guys for your replies. gregjo1948
whiteclipse16
Post by whiteclipse16 » Mon Dec 05, 2016 1:24 pm
Are you in need of an engine grego?
gregjo1948
Post by gregjo1948 » Mon Dec 05, 2016 5:23 pm
whiteclipse16 wrote:Are you in need of an engine grego?
No. I saw a 2010 and 1010 for sale that the swap would make one good machine from the two.
tlock0331
Post by tlock0331 » Sun Dec 18, 2016 7:54 am
whiteclipse16,
I could maybe use one....i have also been thinking about trying to drop a 2/3 - 53 series detroit or maybe building an adapter plate and putting in a 4bt...but if you have a diesel motor. i think my email is open
gregjo1948
Post by gregjo1948 » Sun Dec 18, 2016 8:02 am
tlock0331 wrote:whiteclipse16,
I think a 353 might be a bit too much power for the machine.
Users browsing this forum: Google Adsense [Bot] and 208 guests
