1010 hydraulic valve leak
I purchased a 1010 crawler.It has hydraulic oil leaking out the top of the spool in the control valve.Is there a fix for this or am I looking at replacing the control valve?
it does not have to be perfect as long as it's exact!
Repair
The spool can be pulled out, but condition of your spool will determine if a new cup seal will fix the issue. I had same issue on mine and put new cups in it. It leaks less, that's all I can say.
1010 gas crawler 6 way blade. New to me 3/2015.
Users browsing this forum: No registered users and 202 guests
