1010 radiator
russ61
1010 radiator
Post by russ61 » Mon Oct 31, 2016 3:43 pm
Ok,guys looking for a 1010 gas radiator and oil cooler pricing for now.The local heroin junkie broke into my garage and stole and scraped the one s I had out of my machine.I've got him in jail (should be under it) but I need some kind of pricing to give the court for restitution.Not likely to ever see any of it though. So far I'm up to about $2500 worth of radiators starters he stole.
Thanks for any help Russ
Post by Lavoy » Mon Oct 31, 2016 5:10 pm
Both can be hard to find. I would assume a used radiator at $200 and $500 to recore it. You knew what your old radiator was, only way to be sure of used one you get.
Generic coolers can be found, guessing $100 and up plus plumbing.
JD430C
Post by JD430C » Wed Nov 02, 2016 3:57 pm
I have a couple of the early 1010 radiators where the cooler is separate from the radiator and I think I have one later model where the cooler is built into the bottom. I try to get 100 for them plus shipping. The early ones are in good condition but the later one would need to be recored.
Andrew
Users browsing this forum: KPaXz and 222 guests
