350B
gregjo1948
350B
Post by gregjo1948 » Thu Oct 27, 2016 5:34 am
When engaging the reverser, it jerks the machine abruptly and makes me feel something is going to snap. My 1010 engaged smoothly but firm. Is there any way to tame the engagement before I break something? Thanks, gregjo1948
oljoe
Post by oljoe » Thu Oct 27, 2016 9:56 am
There is a needle valve on the side of the accumulator housing that regulates the shift speed. Chances are that the valve needs to be adjusted. The only experience that I have is with a 450 and it has a plug on the side of the transmission case to access the valve. The valve has a slot for a screwdriver and a lock nut. Rotating the needle valve in and out will adjust the shift rate and intensity.
Joe
gregjo1948
Post by gregjo1948 » Thu Oct 27, 2016 10:10 am
oljoe wrote:There is a needle valve on the side of the accumulator housing that regulates the shift speed. Chances are that the valve needs to be adjusted. The only experience that I have is with a 450 and it has a plug on the side of the transmission case to access the valve. The valve has a slot for a screwdriver and a lock nut. Rotating the needle valve in and out will adjust the shift rate and intensity.
Joe
Thanks!! I'll see if I have the same on my 350B.
jtb51b
Post by jtb51b » Thu Oct 27, 2016 2:18 pm
Its accessible from the bottom. There are 3 of them. Cant remember which is which. A manual has all of this info, they are very thorough for what you pay for one.
JD 350B Loader (unknown serial number)
gregjo1948
Post by gregjo1948 » Thu Oct 27, 2016 7:58 pm
jtb51b wrote:Its accessible from the bottom. There are 3 of them. Cant remember which is which. A manual has all of this info, they are very thorough for what you pay for one.
I have a manual coming. Should have it Monday.
jtb51b
Post by jtb51b » Fri Oct 28, 2016 7:31 pm
You will enjoy that manual. It very detailed and has a lot of pictures. A big help! I just got home from out of town, if you would like I can look in my manual and get you the procedure.
Jason
gregjo1948
Post by gregjo1948 » Sat Oct 29, 2016 4:18 am
jtb51b wrote:You will enjoy that manual. It very detailed and has a lot of pictures. A big help! I just got home from out of town, if you would like I can look in my manual and get you the procedure.
Jason
Having the procedure would be great. I could get it adjusted correctly and not worry about breaking an expensive part by its slamming into motion.
Thanks, gregjo1948
jtb51b
Post by jtb51b » Sat Oct 29, 2016 3:15 pm
Send me your email address and I will send a photo of that page.
Jason
PM if you would prefer.
gregjo1948
Post by gregjo1948 » Sat Nov 05, 2016 3:56 am
jtb51b wrote:Send me your email address and I will send a photo of that page.
Jason
Thanks Jason. I removed the allen wrench plug and turned the adjuster with a flat head screwdriver. I think I turned it cc, if I remember correctly. I turned it a couple times to get the engagement as I wanted it.
Users browsing this forum: Google Adsense [Bot] and 23 guests
