ironyetty
Post
by ironyetty » Sat Feb 10, 2007 7:10 pm
switchhappy
Post
by switchhappy » Sat Feb 10, 2007 9:28 pm
it sounds like your starter is draging, mabe u should take it off and have it checked or re-built for a 12 volt, it wold help to crank it faster.. just my two cents
- Site Admin
Post
by Lavoy » Sat Feb 10, 2007 9:30 pm
I should have a carb kit on hand.
Check your battery cable size, it should be at least #1 if not 1/0. Check your ground strap as well. It could be high amp draw on the starter, but usually the cables are at fault.
whybill
Post
by whybill » Sat Feb 10, 2007 10:04 pm
If the battery in your crawler is flat and the jumper cables are carring the whole load they probably are not heavy enough even using 12volts....most jumper cables any more are only 6 gage and if you are lucky they mightt be 4 gage. not heavy enough to carry the whole load.....you would be better off to put a fresh battery in the crawler and go from there. Check the starter if it has been laying up for some time the critters may have moved in lol dosen[t hurt to clean it up also.
just a guess
Bill
Bill 420c dozer 5 roller
N. E. Alabama
older is better just keep it greased
Users browsing this forum: No registered users and 219 guests
