I think this will add a few years to the life of the ole John Deere 350D. I am not sure if the Wallenstein was really designed for 12 foot Spruce Logs but it handles them with ease. I like how all the weight is on the trailer and the bulldozer does not even know it has a load behind it. The next test will be hemlock logs, but they are much heavier than Spruce that is for sure, but maybe it will work okay?
I am really happy in any case, a lot less trips to the yard, more production, cleaner wood and still productive.
https://scontent-yyz1-1.xx.fbcdn.net/v/ ... e=584424E7
https://scontent-yyz1-1.xx.fbcdn.net/v/ ... e=58808E78
https://scontent-yyz1-1.xx.fbcdn.net/v/ ... e=5855A496
Taking Pressure off the Final Drives
- CuttingEdge
- CuttingEdge
I typically use my Kubota for most firewood and pulpwood logging since it has a winch and can pull the trailer with ease. What I found works great is using the bulldozer to clear brush and make excellent roads for my tractor to twitch.
On the shorter pulpwood and firewood you cannot beat the tractor and trailer combination, as the trailer really is designed for 8' wood. When you put 12 foot wood on like what is in the picture, it tends to lift the 3 point hitch though (even with the winch on it) when the wheels of the trailer hit any sort of dip or incline. Hitching it to the dozer is a different story. It does NOT lift the back of that so the dozer works well for logs. Since the price for logs is so much more valuable then pulpwood, and mud or dirt cannot be on the ends of logs anymore, dozer logging this way pays for itself.
My dozer has got a new set of tracks on it, but for a 350D they only cost around $4500 too. I actually thought about buying a spare set just to have kicking around for that price as who knows what it will be in the future. But who knows if I'll have the tractor in the future either. A 450J sounds nice!
