john deere 350c transmission and final drive oil question
motorworx
Post by motorworx » Thu Feb 14, 2013 7:21 pm
im putting my 350c back togetherand im about to refill the transmission and final drives and i im not sure how to fill the final drives, and was wondering if the transmission and final drives are all one oil resavor.
LeonardL
Post by LeonardL » Fri Feb 15, 2013 12:22 pm
If you are sure you have a "C" model and you are sure you have wet style clutches, then your transmission, clutch housings and final drives are all one common oil. It takes about 11 US gallons of tractor hydraulic fluid. I usually try to pour about 2 1/2 gallons in each clutch housing and the rest in the transmission fill / dipstick port. The system will slowly even itself out and the dipstick in the transmission should show it being full.
StxRancher
Post by StxRancher » Fri Jun 24, 2016 2:27 pm
LeonardL wrote:If you are sure you have a "C" model and you are sure you have wet style clutches, then your transmission, clutch housings and final drives are all one common oil. It takes about 11 US gallons of tractor hydraulic fluid. I usually try to pour about 2 1/2 gallons in each clutch housing and the rest in the transmission fill / dipstick port. The system will slowly even itself out and the dipstick in the transmission should show it being full.
You mean if it has been modified to a common sump...correct? Otherwise you need to fill each one to capacity accordingly. Please correct me if I am wrong.
jtb51b
Post by jtb51b » Fri Jun 24, 2016 4:01 pm
I think that may only matter on a 450C.. Thinking all the 350C's were common.
Jason
JD 350B Loader (unknown serial number)
StxRancher
Post by StxRancher » Fri Jun 24, 2016 5:25 pm
ok,thanks for correcting me. I can only relate to my 450c
jsal
Post by jsal » Mon Jun 27, 2016 7:17 am
I believe common sump does not include your final drives only trans and
steering housing ?
JIM
papyrus
Post by papyrus » Sat Jan 28, 2017 3:26 am
is there a difference between B and C ?
on my 450 B the steering breaks and clutches are dry.
Post by jtrichard » Sat Jan 28, 2017 11:46 am
papyrus wrote:is there a difference between B and C ?
YES "C"s are wet..... "B"s are DRY ( unless you are UNLUCKY :cry: )
Users browsing this forum: No registered users and 82 guests
