Reusing Piston Pins
Reusing Piston Pins
Post by wwattson » Sun Jan 28, 2007 5:49 pm
I'm up to the point of reassembling the engine on my 1010CA project and I'm wondering about reusing the piston pins. All of the pins mic out within limits but the book says to always replace the pins when replacing pistons. The easy answer is to just do what the book says but at $27 a pop for new pins, I'm sort of struggling. Any thoughts?
Jimmy in NC
Post by Jimmy in NC » Sun Jan 28, 2007 5:53 pm
Personally.. I'd put new pins in. To me it would be worth the cost for the peace of mind.
Just my $.02
Jimmy in NC
Post by Lavoy » Sun Jan 28, 2007 7:39 pm
I would have to go with Jimmy too. This is a one shot deal, this rebuild should last you for as long as you own the crawler. Plus, I can think of a lot dumber ways I have shot a hundred dollar bill.
hunter41mag
Post by hunter41mag » Sun Jan 28, 2007 8:37 pm
I also agree with Jimmy and Lavoy. Any part that wears developes a wear pattern to its mating surface. So a used pin will not match up real well to the bore on a new piston (might have high/low spots) and may cause premature failure. Example would be to always use new lifters with a new cam.
Don
Eastern PA
440IC
Users browsing this forum: No registered users and 244 guests
