420 split?
Mikey O
420 split?
Post by Mikey O » Thu May 26, 2016 11:10 pm
I have a a 420 c I bought 15 yrs ago to landscape when I built my house figuring I would sell it when I finished but I never knew about the contagious crawler affliction and low and behold just couldn't part with it, just always have a reason to keep it....long story short I didn't fire it up last 2 yrs and when I spun it over t was slow turning over,main clutch seized and clutch and brake pedal seized together so I thought I'd pull engine to free clutch and found mice got in a missing bellhousing bolt hole and filled entire clutch assembly, bellhousing and reverser tube with seeds, fur,fuzz and corpses of the dead ones. It filled a 5 gal shop vac full it's a mess even starter motor was full. So it's all cleared out, engine on floors down it spins over nicely now but I I'll have to pull clutch and flywheel apart. I have stripped it down gas tank, hydraulics,dash all off , the bolts holding bell housing reverser tube to transmission are out but it will not pull away from the transmission I get about a 1/16 to 1/8 gap top to bottom but it will not pull apart I am only using light force no bars just in case I missed a step. All visible bolts and nuts are off and it will wiggle up and down but not come apart. It's a 420c sn 113724 did I miss a step here
Mike
Post by Lavoy » Fri May 27, 2016 8:24 am
You need to pull the shaft out of the center of the reverser shifter tube about an inch and then it will come apart.
Mikey O
420 split
Post by Mikey O » Sat May 28, 2016 9:58 am
Well Its out and was totally packed with mouse stuff the clutch and brake Shafts and rods are welded together by mouse pee shaft spring is broken as st the front return spring will see if the rod and clutch bushing will separate today
dr1zsk1
Mouse pee is a potent tool
Post by dr1zsk1 » Tue Sep 27, 2016 11:12 am
Mouse pee can weld about anything!
If man can break it man can fix it .. it just takes time and money.
notmeu
Re: Mouse pee is a potent tool
Post by notmeu » Tue Sep 27, 2016 7:08 pm
dr1zsk1 wrote:Mouse pee can weld about anything!
That would be the only thing those pesky varmints are good for!!!
pop pop
Post by pop pop » Wed Sep 28, 2016 10:34 am
its why we invented panther piss :P
Users browsing this forum: No registered users and 285 guests
