JD450 Won't Keep Running
myboyblue85
Post by myboyblue85 » Tue May 03, 2016 10:48 pm
Hey guys, my JD450 had small fire and I had to replace a few things including starter, fuel pump, radiator, injector lines but thankfully engine is still working.
I havent rewired everything but I have the starter connnected and when I push start button it will turn on but will turn off shortly thereafter. I have checked air filter so I know its not that.
Any suggestions of what I need to be checking? Could unrepaired wiring be causing this?
Thank you all in advance
Post by Stan Disbrow » Wed May 04, 2016 4:39 am
There is a fuel flow solenoid on the injector pump. That is the only wire which would be involved. Might now be intermittent, the engine vibration causing power to drop to the solenoid.
mlaclaire
Post by mlaclaire » Mon May 09, 2016 11:53 am
This may be gunk in the fuel tank. If you are getting fuel to the pump and the filter it is not gunk in the tank. My straight 450 would run for a half hour then quit. I pulled the fuel line off from the fuel pump and no gravity feed fuel. I have been carrying a can of compressed air to blow back into the tank, that opens it up for another 30 minutes to sometimes the rest of the day. I dread pulling the tank and cleaning but it maybe the only way for me. :shock:
Les
Post by Les » Mon May 09, 2016 2:36 pm
I had a similar problem, albeit without the fire. My problem was incorrect placement of the fuel filter gaskets that blocked the free flow of fuel through the filter. Not likely your issue, but just thought I'd throw it out there. Good luck.
-- Les
Les
1971 450B Crawler Dozer
Users browsing this forum: No registered users and 33 guests
