Cylinder leak repairs
KSS Const.
Post by KSS Const. » Sun Apr 24, 2016 6:30 pm
I have a leak at the wiper seal on a couple of cylinders on my 9300 backhoe. There doesn't seem to be any issues with the internal seals as the power and hold on those cylinders is fine. Should I rebuild the entire cylinder or can I replace the wipe seal, wear ring and packing on the rod end of the cylinder to take care of the leak?
Post by jtrichard » Sun Apr 24, 2016 8:11 pm
Do the entire cylinder
jsal
Post by jsal » Mon Apr 25, 2016 5:49 am
Have been changing just wipers and rod packing for years with no bad issues saves money too, have two angle cylinders to do real soon on my 350 $30.00 in parts for each.
JIM
KSS Const.
Post by KSS Const. » Mon Apr 25, 2016 6:39 pm
Thanks for the input. I guess the question I really should be asking is if it makes more sense to do the whole cylinder while I'm taking it apart. The cost for parts is dramatically different but with the age of the machine (1983), will the piston seals fail? The machine has not been overused for most of it's life. I bought it from a builder who put up a couple of houses a year and used it for site work. He owned it since about 1986. Does the limited use result in seal failure? I'd like to save the $$ but I don't want to have to take it apart in another few months.
jsal
Post by jsal » Tue Apr 26, 2016 5:10 am
Mine is a 1966 350 dozer have had no issues with not changing piston seals
Users browsing this forum: Google [Bot] and 46 guests
