1010 dozer with bad diesel motor
Robin691
Post by Robin691 » Thu Apr 07, 2016 8:33 pm
is switching the 1010 diesel motor to a 2010 gas motor possible and is this better than considering rebuilding the 1010 diesel or trying to find a diesel replacement?
Post by jtrichard » Thu Apr 07, 2016 9:32 pm
YES it can be done .... What is wrong with the diesel?
Robin691
1010 dozer bad diesel motor
Post by Robin691 » Fri Apr 08, 2016 10:49 am
The diesel motor starts hard, always have to use glow plugs hot or cold and burns one quart of oil per hour when working the machine. I saw a green 2010 gas tractor and thought the easiest approach would be to purchase the tractor and switch the motor. The asking price was 1900, but hoped I could get it for 1200.
Re: 1010 dozer bad diesel motor
Post by Tigerhaze » Fri Apr 08, 2016 2:04 pm
Robin691 wrote:The diesel motor starts hard, always have to use glow plugs hot or cold
Are you sure the glow plugs are working? The 1010 and 2010 diesels pretty much need working glow plugs to start even in warmer weather.
Post by Lavoy » Fri Apr 08, 2016 2:24 pm
1010 won't start at 80 degrees without glow plugs, just a fact of life. Factory recommendation is glow plug for 30 seconds in warm weather.
I would assume a tractor had different throttle linkage than a crawler, gas and diesel have different hoods, tractor does not interchange. Not sure that the reverser disc will bolt to 2010 gas tractor flywheel.
The other unknown is how long the drive train will live at the increased power level. I would assume not long.
Post by mini kahuna » Fri Apr 08, 2016 6:05 pm
you might get her back going with new piston and rings, only problem is your engine has a sleeve deck instead of cylinder sleeves.
if the deck is worn and you have cylinder taper...it will.... you will need a new cylinder deck along with new pistons and rings $$$$$$.
I don't know if the sleeve deck can be bored oversize or not....someone else here will have the answer on that.
1010 loader
Post by jtrichard » Fri Apr 08, 2016 6:55 pm
They DID make over size for 2010 i assume also 1010 but have not been available in years so the answer is YES and NO ..... BUT there are after market decks for 1010 diesel/2010 gas (same one for both)
Robin691
1010 bad diesel motor
Post by Robin691 » Fri Apr 08, 2016 7:18 pm
The glow plugs are brand new and work well just so frustrating to have to use them every time I go to turn the engine on and off! And the addition of 9 to 10 horsepower of the gas motor doesn't seem like it could be detrimental unless your running the machine balls to the wall, which I am not just a home use machine ie, put a driveway in and say tilling a small garden.
I was just wanting to have a turn key and go machine thinking the gas motor could provide that better than the diesel?
And have rebuilt almost everything on this machine except the motor.
Another thing that crossed my mind was could I eliminate the reverser and somehow tie the drivetrain from the gas tractor to the crawler mechanics?
Robin691
1010 diesel bad motor
Post by Robin691 » Fri Apr 08, 2016 7:30 pm
Another thought do you think a better possibility would be to find a gas 1010 or 2010 crawler motor so the reverser flywheel match won't be an issue or are these type engines like finding hens teeth?
Robin691
Post by Robin691 » Fri Apr 08, 2016 7:41 pm
does anyone know a potential parts junkyard where I could find a replacement diesel motor? And or have a spare to take the time to rebuild and then at some point just swap the old one out?
I am about 1 hour and 15 minutes north of Philadelphia so parts closer to this local would be helpful, but I know there is always shipping...
Post by Tigerhaze » Wed Apr 20, 2016 3:18 pm
I think Wegner's tractor parts in Myerstown, PA is in your neck of the woods.
vailvalley59
Post by vailvalley59 » Sun May 01, 2016 11:35 am
You should keep in mind that the diesel will have more pulling power (torque) for the dozer. I find that is an important reason to keep the diesel for this type of equipment Gas might start easier but if you are going to use the unit much at all the diesel is the way to go.
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
Users browsing this forum: Jim B and 185 guests
