40C Front Idler
Loose Tracks
40C Front Idler
Post by Loose Tracks » Mon Apr 04, 2016 6:43 pm
My 40C is a 5 roller, pulled one front idler (19") due to slop. Parts book calls for 2 bushings M 2266 T. OK, got one bushing out, number stamped on outside surface M2234T, underneath was stamped J.B.-T. Can anybody explain the difference in the numbers.
Bore in idler is 2.187. OD of idler shaft (in center) 1.980. The bushing is just a wrapped bushing with 2 oil (grease) grooves.
40U, 40C 4 roller, 40C 5 roller, '56 Mack B61T and a bunch of other Macks
Post by Lavoy » Mon Apr 04, 2016 11:22 pm
Use the M2266T, that is the number you will have to order. Other number could be old number, or reference number that does not relate to part number, not sure.
I have some NOS shafts, and new seals on hand if you need them.
Loose Tracks
Post by Loose Tracks » Tue Apr 05, 2016 6:53 pm
Thanks, Lavoy. Price on shaft and seals, bushings if you have them?
Post by Lavoy » Wed Apr 06, 2016 8:58 am
Shaft is $125, seals are $50/each, bushings $48/each. Should have everything in stock.
Laovy
Users browsing this forum: Jim B, jimmydiesel and 200 guests
