Right Track Wont Turn
b_ware60
Post by b_ware60 » Sat Jan 30, 2016 10:21 pm
I have a 1970's model JD 450. The right track does not turn. I dug the bucket into the ground and lifted the front end of the crawler up. This allowed the left track to just spin while the right track did nothing. I opened the panels under the seat and nothing is turning on the right side. The clutches were replaced on the right side last year. I thought that maybe the track disengaging adjustment screw needed tweaked, but this was not the case. The track did not quite all at once. It slowly stopped working. This leads me to believe that an axle may be stripped out. Any suggestions?
gregjo1948
Post by gregjo1948 » Sun Jan 31, 2016 6:04 am
I think, if the axle is "stripped out", it would have done it instantly, not gradually. I would say it's a clutch out of adjustment and/or the discs are too worn to function from slipping too long before you check what was wrong.
Users browsing this forum: No registered users and 419 guests
