Will a bucket interchange between a 350c and a 450c
I have found a 4 in 1 bucket for a 350C and wondered if it would fit my 450C. It would be simple to measure but i dont have a 350 and the bucket is some distance away. Thank you, Bruce
I have no idea, I'm certain someone will eventually say yes or no but in the meantime I have mine parked outside the back door (dragging firewood trees) and for the upper mount on the loader bucket there are the 2 plates the trunnion pins fit into, on mine the inner ones are 26" apart and the outer ones are 34" apart. If your 450 can accommodate that spacing let me know and I'll get the other dimensions for you.
350 vs 450 bucket
Dear sir,, I measured a 350 parts loader in my yard...
On the backside of the bucket,,, the brackets that hold the pins for the loader arms...
outside of bracket to outside of bracket on opposite side is 33"s
with a 3 3/8"s space for loader arm to slide into..
with 1 1/2" diameter pin...hope that helps.. Mark
same spacing top and bottom conection
Users browsing this forum: No registered users and 148 guests
