2010 fuel system question
I bought a 2010 diesel crawler with a bad engine. The man I bought it from started to remove to engine before I got it. I do not know how the fuel lines are to be routed. Can anyone help me out with some pictures? The dozer is a late model.
Kevin
Kevin
- hunter41mag
I am not familiar with this setup but most two filter diesel fuel systems are set up the following way.
1. From the fuel tank to your primary filter
2. Primary filter to supply pump
3. Supply pump to secondary filter
4. Secondary filter to injection pump
5. Return from injection pump back to tank or item 1 or 2 above (suction side between tank and supply pump)
It would be a good ideal to get the factory manual for this unit. It would show this information plus any other information you will need later.
I hope this helps.
Don
Eastern PA
440IC
I hope this helps.
Don
Eastern PA
440IC
The parts manual may be as helpful, because it provides a detailed schematic of this system as well. I don't remember but the routing may not be shown in that so it is good you are getting the service manual.
The pictures I posted are off a diesel loader; the setup on my loader is very similar but not exactly the same. I wouldn't think the dozer setup is different, but I guess that is possible. I'll try to find pics of my system for comparison and post them.
fuel lines
kevin on my 64 2010 the lines from the right front tank and left rear of tank come togather at settelment bowl then goes into the double filter setup then around the front of the motor into the top of the injection pump the return line comes off the bottom of the injection pump to the fuel tank at the right rear .the primer line also hooks in with the return line. i m sorry i dont have any pictures but i hope this helps you outdslkevin wrote:Thanks for the help so far. It looks to me like the fuel comes out of the filter set up and goes around the front of the engine into the injector pump. Another thing, is there is no fuel pump.
Kevin
Users browsing this forum: No registered users and 294 guests
