NOS MC track frames
mapaduke@yahoo.com
NOS MC track frames
Post by mapaduke@yahoo.com » Thu Jan 07, 2016 6:26 pm
http://rs877.pbsrc.com/albums/ab331/MAP ... 0&fit=clip
I picked these up a couple years ago from a collector and was going to use them until I knotised that the square holes for the carriage bolts are in the wrong spot.
The frame on the right the first hole under the idler is to low and the the hole behind the rear role is to high and should be at the same height that the front on is almost like it was stamped backwards.
The frame on the left has two extra holes at each end?
I think someone at the foundry had a bad day lol
nothing crawles like a deere
