Corking a crawler, 450B
Post by Lavoy » Sun Dec 20, 2015 4:38 pm
I will take a different view on the preheat. I have never done it, had no problems. My uncle had to have welded hundreds of feet of grouser stock in his life, he never said anything about preheat. I will qualify this by saying maybe something modern may have a different pad that may require it, but definitely not on these old girls.
Willie B
Post by Willie B » Sun Dec 20, 2015 4:47 pm
I know nothing of crawler pads, I'm better informed about welding. Preheat is about two things: sudden temperature change, and shrinkage. If steel remained dimensionally constant after solidifying, there would be little need to preheat. As molten steel cools it freezes, as it cools further, it shrinks further. Keeping it hot longer, allows crystals to form into stronger groups of molecules. Depending on the ductility of the weldment, preheat may, or may not be needed.
An optimist is usually wrong, and doomed to disappointment. he is unprepared. A pessimist is usually right, delighted to be wrong, and is well prepared.
Willie B
Post by Willie B » Sun Dec 20, 2015 6:20 pm
[quote="s281jim"]Notmeu, it is welded to the base of the pad, perpendicular to the grouser, an attempt to curb sliding sideways on a hill[/quote]
This is not the technique I have seen. The mechanics I saw do it years ago used grouser stock of a variety one might use to replace worn off grousers. The stock was cut 1/4 the width of the pad, and added to the top of the grouser. If I recall pads with two pieces were held in 1/2" from each end, the next pad got one in the middle of the grouser.
B Town
Post by B Town » Sun Dec 20, 2015 8:21 pm
Here is some good reading
http://www.titussteel.com/our-products/ ... procedure/
preheating will make the high carbon low hydrogen electrode puddle and flow much better. Striking and starting cold with 7018 is not ideal, but it can be done
Willie B
Post by Willie B » Mon Dec 21, 2015 8:26 pm
[quote="B Town"]Here is some good reading
preheating will make the high carbon low hydrogen electrode puddle and flow much better. Striking and starting cold with 7018 is not ideal, but it can be done[/quote]
Preheat yes, and I use two hands. Holding the end of the stick in my off hand gives me the fine control to sneak up on the work, and start the arc. I've not tried one, they tell me the ARC PIG will add an overrunning high voltage/high frequency low current to your welding power. In TIG welding this establishes, and stabilizes the arc. People who have tried it say it makes 7018 child's play.
hydrogeo
Re: Corking a crawler, 450B
Post by hydrogeo » Tue Dec 22, 2015 8:32 am
Willie B wrote:A local logger bought 10 350s at one purchase. He had many other John Deere crawlers and skidders. All of his got corked with alternating 2 or 1 short pieces of grouser stock. At the time I was a kid, the people who did the work are gone. What sort of steel are track pads made of? Can they be welded cold, or is preheat needed? I'm concerned it'll be a big flying saucer should I get side hill in winter. Are there better patterns to use?
Sorry for the hijack, but your post made me think of a story I heard as a kid. I remember hearing that back in the day a crew from said local logger was up scouting a cut off the CC road in the national forest and spotted an abandoned 350 sitting in an old overgrown log header. After some investigation they realized it was one of their machines that they had forgotten there when they pulled off a previous cut years before.
Not sure if it's true but with the size of the fleet he had back then it very well could be.
Willie B
Post by Willie B » Tue Dec 22, 2015 8:55 am
[quote="hydrogeo"][quote="Willie B"]A local logger bought 10 350s at one purchase. He had many other John Deere crawlers and skidders. All of his got corked with alternating 2 or 1 short pieces of grouser stock. At the time I was a kid, the people who did the work are gone. What sort of steel are track pads made of? Can they be welded cold, or is preheat needed? I'm concerned it'll be a big flying saucer should I get side hill in winter. Are there better patterns to use?[/quote]
Not sure if it's true but with the size of the fleet he had back then it very well could be.[/quote]
I've heard the story numerous times from family, and employees. Only change is it was on private property owned by an out of state individual. I can show you the saplings they knocked down retrieving it. Exactly how many years it sat I don't know, I'd guess ten.
Willie B
Post by Willie B » Tue Dec 22, 2015 6:54 pm
[quote="Stan Disbrow"]Hi,
The issue, at least for me, was the machine rotating sideways way too easily on a hillside when plowing snow. Then, the frozen ground acts like a hockey rink and the grousers like skates - and away we go!
I went with the other option, ice caulks. They are conical studs that replace the pad bolts. They act like studs in snow tires, poking their way into the frozen tundra.
They are still on the 420c, even though they are mostly out of a job now (here in NC).
The discussion did become a little unclear there as we also got to discussing snow pads with their alternating grouser height and clearing holes.
Stan[/quote]
Sorry about that, I know only enough to be dangerous. The loggers from my youth knew of this technique because their boss paid them overtime to do it on tractors they would use. Their employer accepted a mortality rate, even his oldest son. Few skid roads were vertical on the mountain. Most were side hill. In the day, they were mostly National Forest. Logging has always been restricted in other seasons in National Forest. Survival required tracks that wouldn't slide sideways on a frozen mountain. I likely called it by the wrong name.
s281jim
Post by s281jim » Tue Dec 22, 2015 7:05 pm
So grousers are just made taller??? Not sure how this deters sliding sideways. I am relatively new to crawlers, but have only seen the added material welded perpendicular to the existing grouser
Willie B
Post by Willie B » Tue Dec 22, 2015 7:15 pm
Taller, but gap toothed. Alternately, a pad grouser will have either two 4" corks on a 16" wide grouser, or a single one in middle. I'll theorize that they rarely encounter pure ice. Typically it's icy, snow, thin soil over rock or ledge. The places I've been are seldom frozen ground. Snow depth is such especially on the east slopes of the Green Mountains that it insulates the ground, allowing underground heat to prevent ground freezing. It isn't until they plow a skid road that it freezes. Often, I believe the carbide tipped tire chains on a rubber tired skidder offer better traction than a crawler.
Post by Stan Disbrow » Wed Dec 23, 2015 5:57 am
I lived atop a mountain in NY State growing up, and Dad used the 420 to plow snow. After the first couple of slip-sideways-and-ice-skate, with snow psds, he added the caulks. They really do work.
Willie B
Post by Willie B » Wed Dec 23, 2015 6:40 am
Where would one get these things?
Willie
Post by Stan Disbrow » Wed Dec 23, 2015 7:36 am
I think from the track parts suppliers these days, although they were available from Deere back when. They are pad bolts with a tall conical top which sticks up slightly above grouser height. Sort of like studs in snow tires.
Of course, one could always make them. Dad had found one set for the 420 lost in our parts shelves (back when we had the dealership). They were too high for the worn grousers, so he cut them all down to match. Then, put half a set on each chain. Half was better than none, and they did the job.
NWJD fan
caulking pads
Post by NWJD fan » Wed Dec 23, 2015 1:58 pm
Scottyb has a post somewhere on here about using 5/8 diameter grade 8 bolts installed through holes in 350 loader pads for ice traction with good effect.
Users browsing this forum: No registered users and 272 guests
