Lifting a crawler.
woodsnwater
Lifting a crawler.
Post by woodsnwater » Mon Nov 23, 2015 11:58 am
Can the lower final drive covers on a 420 support the weight of the machine?
Post by Paul Buhler » Mon Nov 23, 2015 1:43 pm
Yes.
When I have to work on my tracks, I back over a long 4x4 (or two small firewood logs), to get the pans up higher in the air. Then I block under them - snug. I then put a block of firewood or 8x8 under my blade to lift the front end of the machine and the tracks off the ground. Now the 4x4 can be removed, or not. I then use safety jack stands on 2x12 pads under the front cross member, and lower the machine onto them. I've found this to be a secure way to have the machine high enough in the air so that the machine can be run and the tracks spun. Handy for many tasks. Paul
woodsnwater
Post by woodsnwater » Mon Nov 23, 2015 3:09 pm
I think it might have been one of your old posts that I read that in. I just wanted to make sure the pans could support all that weight.
Post by Paul Buhler » Mon Nov 23, 2015 4:21 pm
Yeah, could be. I asked the same question of the board about 5 years ago. Stuff gets hashed and rehashed and I just shared a composite of what I learned and now do when needed. Paul
Users browsing this forum: No registered users and 20 guests
