Spring in shifter mechinism on 420c
woodsnwater
Post by woodsnwater » Wed Nov 18, 2015 10:17 am
Looking at the parts manual for the 420-430 crawlers on page 30-33 there is a spring #21 I believe, part # m3985T. What is this for and where does it go? My shifter handle is loose feeling but it works fine. I was wondering if this spring was used to firm it up somehow. Or do I need a new shifter bearing?
Post by Lavoy » Wed Nov 18, 2015 10:58 am
Spring goes in the shift tower to hold the shifter in the slots. If you don't have the tin shift tower, your crawler does not use it.
Post by Stan Disbrow » Wed Nov 18, 2015 12:10 pm
And, if you have the tower, you really don't need it. The one on my 420c has been broken since at least 1970....
woodsnwater
Post by woodsnwater » Wed Nov 18, 2015 3:29 pm
Ok, yes I have the slots. The shifter is just so easy to move it didn't seem right. Like I said before though , it works perfectly. Thanks for your help again.
Post by Lavoy » Wed Nov 18, 2015 7:29 pm
Then I would put in the spring, it helps to make sure you have the shifter all the way in the slot and keeps it there.
whiteclipse16
Post by whiteclipse16 » Thu Nov 19, 2015 8:33 am
Is the 420 different than a 440. I thought the spring was to ensure the shifter stayed in neutral. My spring holds the shifter nicely in neutral to one side.
Ben
Post by Lavoy » Thu Nov 19, 2015 10:02 am
It does, but it also holds the shifter in the against the little notch in the shift tower when in gear.
Users browsing this forum: No registered users and 185 guests
