Just "Refreshed" my IP pump, now Hard Starting...
Quickly pull the fuel cap and see if you hear suction. Also drain the tank and look for obstruction, had that happen one time too.
- Contact:
Tried this right before it died for the last time.Lavoy wrote:Quickly pull the fuel cap and see if you hear suction. Also drain the tank and look for obstruction, had that happen one time too.
First thing on my list when I get back to it will be to check for fuel at the IP... then trace the lines and make sure I have fuel flowage where needed...
Neil
Not to be a smart ass but check your fuel level in the tank if you haven't. You probably already have but just make sure you have fuel. Check the voltage at the Injector pump and make sure you haven't just lost power to the pump. Check the little things first before going in too deep.
- Contact:
Good suggestions! All my electrical connections are in excellent shape, but that doesn't mean I could have an issue there with a loose connection at the IP shut off solenoid. But would that cause a slow rpm (30 seconds from running to not) fall to 0? Fuel... just put half a tank in it the day before the injector pump died. I think your point of checking the small things first is spot on. I'll recheck the items I ASSUME are good (Fuel level, electrical, etc..) before ripping the fuel system apart again!LeonardL wrote:Not to be a smart ass but check your fuel level in the tank if you haven't. You probably already have but just make sure you have fuel. Check the voltage at the Injector pump and make sure you haven't just lost power to the pump. Check the little things first before going in too deep.
Thanks for the suggestion(s)!
Neil
hard starteing
You may have already checked but if not pull the fuel line at the fuel pump.If you don.t have a good flow loosen the tank cap and blow air into the fuel line with a compressor that will unplug the screen at the bottom of tank .that's the quick fix but the tank will have to be cleaned to solve the problem
68 350 loader
79 350c loader
88 case 580k 4x4
89 ford 2120 4x4
79 350c loader
88 case 580k 4x4
89 ford 2120 4x4
More questions for you... things to check.
Did you replace the Housing Pressure regulator Valve (Stanadyne #15830) when did your rebuild? That is the little fitting that screws into the top of the housing that takes housing leakage/drain flow back to the tank.
Did you use the updated damper ring "EIC" (Stanadyne #29111) or just replace the pellathane ring itself?
Have you checked the pump inlet strainer? That is with the fitting that is the inlet of the pump.
450C Track Loader
291457T
291457T
- Contact:
Turns out that it was just debris in the fuel tank screen. Blew it out with compressed air and it now flows fuel like a fire hose.... Now its just a matter of how fast it plugs back up. If it happens quickly, I'll pull the tank and clean it out. The good thing is now I know what the problem is...DrLoch wrote:More questions for you... things to check.
Is there an easy way to clean out the tank without removing it?
Thanks to EVERYONE for all the advice and information on this one!
Neil
Should be a fairly large drain plug in the bottom of the tank. Pull the plug, steam or power wash the tank out and let dry.
- Contact:
It depends on what kind of debris it is. I have done as Lavoy suggested and then also rigged a shop-vac with a small diameter piece of plastic pipe to get down in the tank and vacuum out what was left. It's a slow process and takes a while to do.
However, if it is a rust issue, then the tank will have to be removed and cleaned thoroughly by using an acid wash and then lined with Red-Kote or some other tank liner. I just did a tank for a guy that had been taken over by rust. The rust was flaking off and stopping up everything. His issue was so bad that it had actually completely clogged the fuel line all the way up to the fuel filter.
Gah! That is a *lot* of rust!
I have washed plain old dirt out by using a garden sprayer filled with kerosene after removing the drain plug. Works on the older tanks after removing the bowl, too.
- Contact:
Thanks for all the suggestions! The good thing is, the tank on this dozer is in pretty clean condition and rust free... but you can see stuff floating at the bottom of the tank when you shine a flashlight down in there. Sounds like it should be an easy fix... maybe a little time consuming, but easy non-the-less. (I like these kinds of fixes!Stan Disbrow wrote:Hi,
Neil
Users browsing this forum: No registered users and 241 guests
