Lindeman parts question.
weebz90
Post by weebz90 » Tue Oct 13, 2015 10:03 am
Im working on a Lindeman crawler and the seal/fitting around the spool valve on the hydraulic pump is leaking. Does anyone know where I could get this part? Or does anyone know if that is just a lip seal in the fitting that can be replaced?
Post by Lavoy » Tue Oct 13, 2015 1:43 pm
You will have to take it apart and see if you can identify what type of seal it is.
weebz90
Post by weebz90 » Tue Oct 13, 2015 2:26 pm
I was just scared to do that cause I didn't want to make the leak worse than it is. I was just curious if anyone else has ran into this issue and what they did to fix it.
Users browsing this forum: No registered users and 317 guests
