Ummm random bolt I found on the ground after using my 440
michaelkittrell
Post by michaelkittrell » Fri Oct 09, 2015 3:34 pm
Umm I found a random bolt on the ground after using my 440.
Can someone please identify it and tell me where to put it back? Might need a new one, the upper threads look worn down, but the bottom ones look good.
Looks like its about 11/16" shaft, 1 1/16" head, 1.5" length and about a 3/32" thread.
http://imgur.com/Ps8WGJo
http://imgur.com/yPuRWae
http://imgur.com/DFc7hhV
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Fri Oct 09, 2015 4:08 pm
My best guess is that it might be a bolt from the front skid plate I believe there are three on each side holding it to the frame rail's.
nothing crawles like a deere
Jaybird
Post by Jaybird » Fri Oct 09, 2015 4:56 pm
Looks like a bolt from one of the motor mounts to me .Might have jiggled out of the front end ( lower part)
GaCatskinner
Post by GaCatskinner » Fri Oct 09, 2015 8:53 pm
Check the blots where the trans mounts to the engine. There should be four bolts about that size. I had one that had backed out and was just setting in its hole waiting to fall out.
Users browsing this forum: No registered users and 25 guests
