350B Weight
dandy
350B Weight
Post by dandy » Thu Sep 24, 2015 9:01 am
How much does a JD 350B with a 6 way blade weigh?
Thanks Dan
Post by Tigerhaze » Thu Sep 24, 2015 9:39 am
The 350B bare crawler weighs between 8,500 pounds and 10,000 pounds depending on whether you have gas or diesel and whether you have standard or wide pads. The available sheets I have don't have the dozer blade attachment, but the 350B crawler with loader attachment weighs approx. 12,000 pounds so you can assume it is somewhere in between.
For future reference to yourself and others, many of the spec sheets can be found here (kudos to Murphy Tractor, my local JD industrial rep who provided them):
http://www.murphyused.com/specs.php
NWJD fan
350B weight
Post by NWJD fan » Thu Sep 24, 2015 1:58 pm
350b 6 way dozer canopy no rear mounted equipment should be close to 10,600 pounds.
Users browsing this forum: No registered users and 241 guests
