1010 stuck track frames
Post by mini kahuna » Sun Sep 20, 2015 4:41 pm
for the last three weeks been dealing with a 1010,trying to remove track frames and they are fused to the rear cross bar.
I have read most of the posts on this subject and have found some good ideas but nothing to date has gotten them to break their hold.
Lavoy has also been coaching me and given me several ideas but they still are fused together like one piece.
Lavoy's tip of pressure washing has eaten away a lot of crap that is packed in there...they still won't give.
anybody recently been threw this problem and gotten them to let go......right now I feel like I am attempting the impossible!!!!!
notmeu
Re: 1010 stuck track frames
Post by notmeu » Sun Sep 20, 2015 6:13 pm
Try some heat using a rosebud tipped torch. Its done wonders for me working on these old girls......
Post by mini kahuna » Sun Sep 20, 2015 8:35 pm
thanks, I don't have one but will get one by next weekend and heat the #@$%# out of it.
notmeu
Post by notmeu » Mon Sep 21, 2015 4:30 am
It won't take too much heat to get it done. Just enough to discolor the metal to a grey color, you shouldn't have to get it glowing red by any means.... too much heat can do some damage!!!!
pop pop
Post by pop pop » Mon Sep 21, 2015 9:56 pm
hydraulic jack,
Post by mini kahuna » Tue Sep 22, 2015 5:24 am
jacks,air chisel, heat, cussing etc. no movement yet.
Post by Tigerhaze » Tue Sep 22, 2015 6:00 pm
Believe it or not I have used dry ice to free up stuck metal parts- it can cause local contraction of parts and have the same localized effect on breaking up rust or crud as heating. However when it has been successful for me is relative thin steel parts like stuck brake drums on autos- I don't know that it would work with more massive steel and iron like on a crawler crossframe. I would go with heating using a Rosebud if you have it but another potential option to consider.
pop pop
Post by pop pop » Fri Sep 25, 2015 6:22 am
its not welded is it? a jack with a big block ,timber should do something. you can try heating and as it cools let it suck in some panther piss.
Users browsing this forum: No registered users and 309 guests
