fluids filters and capacities
Facts and knowledgebase about John Deere crawlers
Post by digitup2 » Thu Jul 26, 2012 8:21 pm
Image[/img]
ImageNither I or my daughter could get these things any bigger so if some one can here is the info from a 1983 publication of Deere's own showing filter and o ring part #as well as fluid and amount needed to fill the area to capacity .Digitup.
CCWKen
Post by CCWKen » Mon Aug 17, 2015 12:52 pm
Wow! Great intentions but way too small to read. :(
Looking for fluid caps on 420C trans and final. Got all excited when I saw the topic then let-down city. Bummer!
Thanks for trying though.
Ken
JD420C, Ford 3910, IH 2606, Kenbota G32XKS
Post by Stan Disbrow » Tue Aug 18, 2015 6:51 am
I will head for the shop in a little bit and look that up for you....
The pics are a tad too low res for me to do anything with them, though.
Post by Stan Disbrow » Tue Aug 18, 2015 8:25 am
420c
Fuel: 10.5 Gallons
Crankcase: 5 Quarts
Trans and Diff: 6 1/2 Quarts
Final Drives: 7/8 Quart (each)
Cooling: 3 1/2 Gallons
Hydraulic: 9 Quarts (single or dual cylinder)
Edit: As long as I am into manuals in the shop...
40c
Fuel: 10.5 Gallons
Crankcase: 5 Quarts
Hydraulic: 9 Quarts (single cylinder)
11 Quarts (Integral System)
440ic
Fuel: 10.5 Gallons
Crankcase: 5 Quarts
Trans and Diff: 8 Quarts
Cooling: 2 3/4 Gallons
So, all the old iron is pretty much the same.
CCWKen
Post by CCWKen » Tue Aug 18, 2015 10:31 am
Thank you, Stan!
