Steering clutch housing plug material JD350
Toofarnorth
Post by Toofarnorth » Tue May 19, 2015 7:29 pm
During replacement of my steering clutches and freeing up all the rusted linkage I discovered that my housing had a crack right through the threaded housing to frame bolt hole running another 4" into the case. I had the case "professionally" repaired. When I got it back I noticed the plug material that sealed the bottom hole under the throwout bearing shaft is missing.
What was that? Is it some sort of epoxy just to keep water from infiltrating? The shaft must move in that bore so it can't bind to the shaft.
JB weld?
JD 350 "unknown serial" diesel with a hydraulic 6-way and a 3315 power winch.
Mahindra 5500 4wd
Chevy k30 dually Dump
Cub diesel UTV dump
Post by Lavoy » Wed May 20, 2015 12:29 am
It is a flat freeze plug, should be current from Deere, or any auto parts house.
Toofarnorth
Post by Toofarnorth » Wed May 20, 2015 4:25 pm
Thanks Lavoy,
The service or tech manual never mention it. I'm missing both sides...
Mahindra 5500 4wd
Cub diesel UTV dump
Post by Lavoy » Thu May 21, 2015 8:15 am
1 1/4" flat plug, it is shown in the parts manual.
Users browsing this forum: No registered users and 319 guests
