north country dozer
Post
by north country dozer » Wed May 20, 2015 7:52 pm
1981 450c... Noticed today after about 2+ hours of running her above 1500 rpms that my trans fluid gauge was going in to the red. Is this most likely an indication of needing to replace fluid? Thanks in advance for any replies[/quote]
DrLoch
Post
by DrLoch » Thu May 21, 2015 6:51 am
Does the fluid look milky colored? Also, there is a cleanable filter down low on the right side, that is where the trans temp gauge sending unit is. I changed my gauges to show temp not just green, yellow, red.
450C Track Loader
291457T
DrLoch
Post
by DrLoch » Fri May 22, 2015 8:14 am
Also, make sure the heat exchanger/radiator is not blocked or full of dirt. On mine it's the smaller one on the left if looking back through the grille opening. The screw on filter is right there as well.
450C Track Loader
291457T
suzkdoc
Post
by suzkdoc » Fri May 22, 2015 8:38 pm
Drloch. What temp does your 450c trans run at ?
DrLoch
Post
by DrLoch » Sat May 23, 2015 5:22 am
160 - 180 Depending on the weather and what I'm doing with it. Engine runs at the same temps as well.
450C Track Loader
291457T
north country dozer
Post
by north country dozer » Wed May 27, 2015 5:28 am
Thank you very much for info. My engine temp was running hot as well with the trans temp. don't know actual temp though only green and red on both gauges. I was not high into the red but just in a little bit so I lower the idle and it stayed right around the beginning of red mark. is that okay?
Users browsing this forum: No registered users and 159 guests
