Oil Filter Cover
foxd
Oil Filter Cover
Post by foxd » Wed May 13, 2015 3:00 pm
I have a question about the oil filter cover on an MC, 40, 420, 430, etc.
Most of the filter cover's I have seen look like this:
However, I have run across a few that look like this on the top:
I have always assumed that these have been overtighten at some point in time and have been collapsed in.
These are fairly heavy material and it seems to me like they would take quite a bit to collapse them like this.
Am I correct that these are bent or were there some made like this?
Thanks Dave
'39 B, '48 B, '49 A, '50 B, '54 40U, '55 40U, '59 430U, '60 430C
pop pop
Post by pop pop » Thu May 14, 2015 5:31 am
that looks factory to me Dave
Post by Stan Disbrow » Thu May 14, 2015 6:31 am
I have seen more like photo A than B, but they were manufactured both ways.
Post by Lavoy » Thu May 14, 2015 8:49 am
B has been crushed by over tightening.
Post by Stan Disbrow » Thu May 14, 2015 10:51 am
How in heck does that happen?? (!)
Folks must use a pretty long wrench to do that to one. Maybe a big, fat monkey wrench?
It must happen pretty often, given the number I have seen like that. Plus, it looks uniform enough that I always figured some were just made that way.
Sheesh.....
foxd
Post by foxd » Thu May 14, 2015 3:45 pm
That was my thoughts as well Stan, they always look to be very uniform when crushed.
Post by Lavoy » Fri May 15, 2015 7:40 am
Sure, no sense replacing the gasket when it leaks, just put a big box end on there and crush the hell out of it, that'll fix the problem! :lol:
BradE
Oil Filter Cover Replacement?
Post by BradE » Fri Jun 05, 2015 5:58 am
I just changed the oil and filter in my 55 40C. But oil is now slowly seeping from the nut at the top of the cover. It's hard to be 100% sure about the bottom seal as oil slowly moved to where the cover meets the assembly.
I tightened this as much as I dare. It wasn't leaking before, and I really wish I had left it alone, but not having had this problem with my first 40C, I thought a simple filter change would be a walk in the park!
Would a replacement filter cover solve this problem? Used, I'm sure.
Are these available? If so, where and how much?
JD 40C 4 roll 1955, snow tracks and sprockets from a 350
Post by Lavoy » Sat Jun 06, 2015 4:29 pm
I should have one on hand, give me a call Monday.
lavoy
Users browsing this forum: KPaXz, yellowcrawler and 22 guests
